Chevy Truck Flooding Out/Won't Start
Old Feb 23, 2013 | 4:34 PM
Scott Swihart's Avatar
Default Chevy Truck Flooding Out/Won't Start
I am working on a 1981 C10 pickup 350. I have spark, checked firing order, checked the float, needles, and seats in the carb. But it keeps flooding out and backfiring.
Old Feb 23, 2013 | 4:49 PM
kevinkpk's Avatar
Take a wood or plastic handled screwdriver and pop it on the float bowl of the carb a few times. Sounds like the float is stuck
Old Feb 23, 2013 | 8:09 PM
kevinkpk.....thank you for the suggestion. I checked the float, checked the needles, and seats in the carb and those are fine. The carb itself was replaced 1.5 years ago but I did pull it out and everything checked out good. I will check the compression tomorrow since that is the only thing I haven't tested out of all the obvious fixes for this issue.
Old Feb 25, 2013 | 7:21 PM
stanman's Avatar
check inside the spark plug wire connectors, dist cap and plugs.
Plugs could be bad or could have slipped time if the dist wasn't tight.
Old Feb 25, 2013 | 10:04 PM
kevinkpk's Avatar
Still sounds like the float is too high, too much gas
Old Mar 5, 2013 | 3:33 PM
stanman's Avatar
I had an issue kinda like this a few months back on my 79 350.
some of my spark plugs went bad got fowled. It cuased the rest of the plugs to flood so I replaced them all and it started up. But then my fuel pump went bad and my ignition fuse needed a slightly higher amp fuse. Always started on the first turn.
350andstrong
Dec 19, 2014 11:00 AM
Scott Swihart
Feb 23, 2013 11:04 PM
Sykotikal
Camaro
Oct 20, 2011 4:00 PM
90burb
Apr 22, 2006 4:49 PM
