Chugging in overdrive at low rpms but fine in other gears
Old Mar 4, 2012 | 6:27 PM
Chevy5's Avatar
Default Chugging in overdrive at low rpms but fine in other gears
I have a chevy 1500 and my truck is chugging in overdrive at 1500 rpms but its fine in other gears and if you are at higher rpms it runs fine. When i say it chugs it goes from 1500 rmps to 2000 and just kinda keeps jumping. but if i had it in 3rd it wouldnt do it. just in overdrive. it makes a vroom vroom vroom....ect. its so annoying and probably killing my gas milage. someone please help i dont know what to do. and its not throwing any codes so i really dont know whats going on. i just changed the plugs, cap and rotor. did nothing..
thanks for looking
Old Apr 29, 2012 | 3:44 PM
likitysplit's Avatar
Thumbs up using od
i have a 98 1500 truck v6 and never use the overdrive gear except when im on the highway. use only 3 gear for most of my driving. it will go into od as soon as it can and bog rite down so i never use it.
Old May 1, 2012 | 8:50 PM
cleveland63b's Avatar
is it on flat roads or under load like going up hills? can you cruise at those rpms at lower speeds with no issue?
Old May 2, 2012 | 7:04 PM
Default using od
i think they designed these trannys to go into 4 gear as soon as it can for gas mileage but what happens is it down shifts constantly if your not on the highway and gets overworked. i actually read that in a chevy book and they recomended not using od at all except on the hiway. when mine reached 100k miles i took it to a tranny place and had it fully serviced for a 100 bucks. the guy said it was in great shape. i would suggest doin that and get a pro apinion . good luck, another thing , your not gonna hurt it by not putting it in od , even at hiway speeds, i do it all the time.
snake91876
Oct 13, 2012 3:41 PM
SILVERAD01
Jan 21, 2009 9:14 AM
survivaldog
Dec 7, 2008 4:44 PM
Beejay
Aug 31, 2008 7:35 PM
Manor_Mullet
Apr 28, 2008 2:13 PM
