Cleaning EGR valve without taking it out?
Old Jun 27, 2013 | 9:40 PM
mike390's Avatar
Default Cleaning EGR valve without taking it out?
Im getting the engine code for a faulty EGR valve, I was told that I could jsut soak it in carborator cleaner and it should remove all the guck that is causing the solenoids to stick. I tried removing it but the bolt it covered in rust and grime and wont move even if I heat it.
I dont really want to break the bolt, I was wondering if anyone knew a method of cleaning this thing without removing it?
Thanks!
Old Jun 28, 2013 | 11:12 AM
Spray it with PB Blaster and tap on the bolt head to start a vibration and the blaster will work its way into the threads if you are lucky. This is a good method for removing stuck bolts. You have to remove it to clean it.
One to Remember
Jul 11, 2014 5:57 AM
sgt
May 21, 2013 11:35 PM
wmiller1337
Jan 9, 2011 10:01 PM
utz
Aug 23, 2010 8:57 PM
DaveM1
Feb 9, 2008 9:13 PM
