coolant smell but no leak...
Old Nov 22, 2022 | 7:02 AM
Hykes's Avatar
Default coolant smell but no leak...
I have a 2003 Chevy Express 1500, I've had it for 2 years and since I bough it, after driving for a while I would smell coolant only when I get out of the van. I've had it to the shop to investigate the smell and they did a pressure test and looked it over and found nothing. It's been 2 years now and nothing has gone wrong with it and nothing has ever been found, but still smell coolant after driving. Does anyone have any experience with an issue like this or have any suggestions..? Any advice is appreciated, thanks!
Old Nov 23, 2022 | 8:39 AM
oilcanhenry's Avatar
Well its coming from somewhere. Are you adding coolant to your Chevy? No leak out of the climate control box?
Old Nov 25, 2022 | 11:20 AM
Hykes's Avatar
No the coolant level hasn't ever gone down, never had to add any..
Old Nov 27, 2022 | 10:02 PM
Are you checking your coolant reservoir level? I'm hoping your heater core ins't leaking. Even a small amount of coolant would cause this smell.
Were I you I'd try some Alumiseal. If the heater is leaking very slowly, this should seal it up. It wont plug your radiator or heater up either. You'll have to add it with the motor hot, then drive it with the heater on full. I hope this helps you out.
Old Nov 30, 2022 | 1:37 PM
Hykes's Avatar
Are you checking your coolant reservoir level? I'm hoping your heater core isn't leaking. Even a small amount of coolant would cause this smell.
Thank you I appreciate the advise!!
Old Nov 30, 2022 | 9:22 PM
Ozlhuvuadojo's Avatar
Try to scan the entire engine compartment; the leak could be coming from somewhere else under the hood. If the smell is stronger inside your vehicle than outside of it, the problem could be inside the heater.
Old Dec 1, 2022 | 11:16 AM
hanky's Avatar
Something to keep in mind,
Performing a cooling system pressure test when the coolant is warm or hot is not accurate because the parts expand and a leak may not show up.
It should be done when cold.
If a water pump seal is seeping , the trace of coolant is there and the seep stops when warm, but the odor gets blown around the engine comparment and because the leak is only visible at the bottom of the water pump , it may not be easily found.
Old Dec 1, 2022 | 4:18 PM
Rednucleus's Avatar
OP says this has been going on for 2 years, and he's never added coolant. Doesn't sound like a leak to me. Even a tiny one that you can smell over 2 years should eventually require some coolant. Maybe he's just smelling coolant fumes when it expands back in to the reservoir?? I believe the reservoir has a vent on it.
Old Dec 3, 2022 | 5:05 AM
You are most welcome, Hykes. That is what we are here for.
Old Dec 3, 2022 | 5:23 AM
Sure, most have a small hole in the middle of the reservoir cap.to vent the air.
74Stylez
Mar 9, 2022 8:17 AM
BooBoo1965
Aug 23, 2021 6:01 AM
Machine213
Sep 19, 2017 12:03 AM
murdoch3732
Apr 28, 2015 11:09 AM
kpraytor
Dec 8, 2011 12:44 PM
