Cruise control problem
Hello
I own a 2008 Chevy Silverado 4x4 extended cab pick up truck.
Recently the cruise control works sometimes & then doesn't work.
I'm thinking the control switch on the steering wheel....any suggestions?
If it is the switch how much approx for a new one & how difficult is it to replace?
Thanks
Thanks
I'd do a little more checking, as I think I have heard about the brake switch also being a possible cause of cruise control not working...
might want to check under the dash and check out the switch(s) attached to the brake pedal...
I believe you are correct.....something definitely going on with the brake pedal.
Will do some more checking.
Thanks again
pcwilcox
October 21st, 2013 11:00 AM
liljoe66
August 5th, 2011 12:44 PM
tkdunn
June 20th, 2010 11:15 PM
