Cruise control problem
Old Sep 16, 2013 | 11:53 AM
Slider001's Avatar
Default Cruise control problem
Hello
I own a 2008 Chevy Silverado 4x4 extended cab pick up truck.
Recently the cruise control works sometimes & then doesn't work.
I'm thinking the control switch on the steering wheel....any suggestions?
If it is the switch how much approx for a new one & how difficult is it to replace?
Thanks
Old Sep 16, 2013 | 2:18 PM
I'd do a little more checking, as I think I have heard about the brake switch also being a possible cause of cruise control not working...
might want to check under the dash and check out the switch(s) attached to the brake pedal...
Old Sep 18, 2013 | 6:18 PM
Slider001's Avatar
Thanks so much for the help......
I believe you are correct.....something definitely going on with the brake pedal.
Will do some more checking.
Thanks again
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
tkdunn
Jun 20, 2010 11:15 PM
kbridge234
Sep 4, 2008 10:03 AM
esbornand
Jan 1, 2007 4:26 PM
