Distributor Gear BBC Roller Cam
Old Jul 29, 2020 | 2:48 AM
olschoolchev's Avatar
Default Distributor Gear BBC Roller Cam
I'm having a '73 454 built for a street 70 Chevelle, running first roller cam so purchased an AC Delco Distributor Gear P/N 19052845 . Builder tells me Distributor Gear Pin Hole is not the same size on both sides of shaft, one side has a step and one doesn't but builder nor I know why. Builder believes machining of the Gear Pin Hole is needed to accommodate Pin. Has anyone run into this? Also concerned maybe there is a reason for the step on one side of shaft...? Many thanks,
Old Jul 30, 2020 | 8:30 AM
I bought a second Gear and it also has the step....so still not sure what the step is for or if we should bore hole out....any help or suggestions appreciated! Thanks!
shetluck
Feb 27, 2014 2:11 PM
stevenh
Nov 3, 2013 9:13 PM
shetluck
Oct 22, 2013 4:37 AM
bowtietwist
Apr 1, 2012 8:12 PM
454 dually
Aug 31, 2006 10:43 AM
