Distributor rebuild.
#11
Also have it in my motorhome 220$ but starting without problems after 8 months of standing with no chargers or whatever + 5 years repl. warranty.
#14
Nope, there is no filter on a smog pump.
The blades on the pump are supposed to help throw dirt and dust out, but if you are in lots of dust, you are up the creek with no paddle. The old man had a 1969 C-60 medium-duty 4-barrel Holly and a 366 cubic inch mill with a smog pump, 5-speed stick with an electronic two-speed axle and closed chambered heads. Went in LOTS of dust, off-road. Between the smog pumps and the diverter valves, we spent a lot of $$$ on that P-O-S, until I found out that it was not required. I ripped that entire system off; blocked the exhaust port holes with steel plugs,
Threw the entire speed-limiting system off, installed a distributor with vacuum advance, and electronic ignition; chucked the smogged-out Holley carburetor for a new one that was not part of the speed limiting system. Thankfully they didn't use serpentine belts back then, just V-belts. Increased horsepower and fuel mileage by a lot. Like 5 MPG to 7.5 MPG. I hate smog pumps!
Dmitriy Ch. (June 20th, 2020)
rjsasaoka
October 6th, 2013 12:00 AM
