engine heater question
Old Aug 31, 2021 | 7:35 PM
lagwagon777's Avatar
Default engine heater question
If pictures would help aid in this question, I will take and post some. I live in Alaska where almost every car has a number of heaters on it to keep it from freezing solid. My car has 3 heaters...a battery pad, and engine block (freeze plug) heater, and likely an oil pan heater (I have not crawled under the vehicle to identify). these 3 heaters plug into a 3-way extension cord (this is within the engine compartment), and that cord that sticks out of my grill, so I can plug the car in.
Two of the heaters are two prong, the other is a 3 prong.When I plug the car into the wall outlet, the GFI trips and power shuts off. What I have found is that the 3 prong heater is causing the GFI to trip. I have partially traced the cord and the heater was dealer installed, but it travels down the engine compartment to the frame and then heads back towards the engine. I have not crawled under the truck to fully trace to determine the exact heater. So here comes my question:
Can that 3 prong heater be tested to determine if it needs to be replaced? I have a multimeter if that helps, but I need to get this figured out before it gets too cold. Thanks for your help everyone.
Old Sep 1, 2021 | 3:52 AM
oilcanhenry's Avatar
These all run on 120 volts AC?
Old Sep 1, 2021 | 4:23 PM
they do, yes
Old Sep 1, 2021 | 10:28 PM
the third prong (round) is the ground. power will run through the other two prongs...flat.
to test a block heater ...unplug it and measure the ohm reading across the flat prongs with a meter....most block heaters measure approx 35 ohms. not sure what a battery pad or oil heater are resistance wise but i suspect if the resistance is low....the element is shorted.
Old Sep 1, 2021 | 11:19 PM
So I set my multimeter to resistance ohms? I will take a reading and post it here.
ChevyIshi
1988 - 1998 (GMT400)
17
Jan 24, 2019 4:46 PM
Rick1970
Nova & Chevy II
Mar 5, 2016 4:17 PM
joelvr
Jan 9, 2012 5:02 PM
Bud Light
Feb 14, 2007 6:23 PM
