Engine not starting
Old Feb 15, 2008 | 5:26 PM
fireguy305's Avatar
Default Engine not starting
I have a 1990 GM pick-up with a 5.7 liter 350 engine. Just recently I tried to start it and it would not start. I thought maybe it was the cap, rotor, plugs or wires. I checked them all and everything seems to working. The engine is also getting gas based on the smell at the throttle body and visually seeing it coming out of the injectors. Does anyone have any idea why the engine will not start? I am not sure whether its a computer module thing or the timing belt/chain?
Old Feb 15, 2008 | 10:40 PM
EvansBlue's Avatar
Default RE: Engine not starting
Sounds like a timing issue to me.
Old Feb 16, 2008 | 10:28 PM
ed39's Avatar
well see wat you dont have either no spark or no fuel?
Old Feb 17, 2008 | 9:55 AM
fireguy305's Avatar
I have both spark and fuel. I double checked the wires and plugs and definitley get spark action. I also see fuel spraying into the throttle body from the injectors.
Old Feb 18, 2008 | 8:32 AM
dewey's Avatar
How did you check for spark? Did you have spark at several plugs or just off the coil wire?
I've seen injector spray patterns that looked good, but the pressure was half of what it should have been. If you pour a little gas down the throttle-body does it help?
Are there any codes? I've seen faulty sensor signals cause a no start.
Old Feb 18, 2008 | 7:03 PM
fireguy305's Avatar
I checked the wires first by taking a screw drive and inserting into the wire end and keeping it close to a ground. When cranking the engine you can see if your getting any power through the wire all the way back to the distributor/rotor/coil and cap. After seeing that I got power through there I then took out a spark plug and connected the wire to it and started to crank the engine. Again I was able to see spark from the spark plug.
As for codes I haven't checked. I do get the service engine soon light but it doesn't flash. I need to get a code breaker thing or whatever its called in order to see if there is an issue. What type of sensors would not allow the engine to start?
Old Feb 21, 2008 | 7:45 PM
ktm521's Avatar
I would check compression that is the last thing you need to start.
Old Feb 21, 2008 | 8:39 PM
kerpal's Avatar
Any updates about you car??
________________________
autopartswarehouse
krustyjonez
May 17, 2011 8:02 PM
drmartin
Mar 22, 2010 9:26 AM
payshoot
Dec 5, 2005 9:54 PM
aimin74
Oct 6, 2004 2:10 PM
