Engine Swap
Old Jun 14, 2008 | 3:51 PM
area1509's Avatar
Default Engine Swap
What are the differences issues with replacing the engine in my 1998 GMC 305 Vortex MPFI with this one http://phoenix.craigslist.org/pts/712536014.html ? Will it accept all of the sensors wiring etc. Thanks for your help AJ
Old Jun 17, 2008 | 7:26 AM
BurninRubber92's Avatar
Default RE: Engine Swap
There shouldn't be any problems, but if it is an EFI rather than an MPFI there will be an issue and you'll need a wiring kit. My advice is to send the guy an email and ask if it is and EFI or MPFI and then take it from there.
Old Jun 17, 2008 | 5:53 PM
area1509's Avatar
I heard that the intake manifold will not bolt up is this true?
Mine is a 305 Vortec MPFI The fuel spider is under a black cover, for the longest time I thought it had 2 injectors but on closer inspection it has an injector at each intake valve.
cueman
Feb 6, 2012 9:37 PM
BigSteve1206
May 16, 2006 8:50 PM
cleveman1
May 1, 2006 1:05 PM
Iowajeepin
Chevelle & El Camino
Apr 2, 2005 1:50 PM
