Extended Crank
Old Sep 27, 2024 | 11:07 AM
Boggie10's Avatar
Default Extended Crank
I have a 2013 Chevy 3500 HD 6.6L that has an extended crank before it starts. Fuel pressure is 4656 at idle. I heard this year and model could have an internal crack in the fuel housing is this correct??
Old Oct 14, 2024 | 6:23 PM
jonexo's Avatar
It is true that some Chevy models, including the 2013 3500 HD, have had issues with cracked fuel housings or fuel pressure regulator problems. A fuel pressure reading of 4656 PSI at idle sounds excessively high, which could indicate a problem with the fuel pump or pressure regulator.
Firemanjoek
Jan 29, 2024 2:38 PM
mmartin8888
Nov 9, 2022 10:01 PM
Itsalongstory
2007 - 2013 (GMT900)
Oct 26, 2021 5:55 PM
