Fuel problem
Old Jun 26, 2007 | 7:28 PM
lorne's Avatar
Default Fuel problem
I believe its a 2x4 converted to a 4x4...but anyways,
it has a 305 with the tbi system. nothing more than typical. the problem with it thou is that it uses more litres than it drives in miles. upon normal servicingand scoping it, i have yet to figure out the problem withany electrical issue. istripped the motor down to the block (but left thepistons in) and haveyet to see a mechanical failure. i checked the cam, visually inspected the valves, checked the valve springs for firmness (but i havent checked the lifters , but they didnt sound bad). did a whole lot of visual with other parts that i've removed.The pulleys all spun freely, but i should get a newwater pump.
i dont know what else to do but do a total re-build, but if i was to do that, i wouldrather then get a 350 or larger that would fit.what is the best wayto figure that out anyways, and the electrical issues that may occur if i go with a direct port efi system..and so on...?
anyways,as id ratherjust figure this out for now due to financial reasons, can anyone getideas out and i will check them out..?
thanks for the help
hunter10220
May 18, 2011 8:37 PM
scottkern3
Dec 7, 2009 7:53 PM
harascho
May 11, 2009 2:10 AM
MrPuzzlez
Jan 4, 2009 12:02 AM
