Fuel tank venting issue!!
Old February 3rd, 2010 | 12:53 AM
call0300's Avatar
Exclamation Fuel tank venting issue!!
I have a 2003 suburban 1500 5.3L and I am having a major gas odor coming from the truck after it has been runnging for at least 2 hours. When I remove the gas cap I get literally blown away and misted with gas. It seems like the tank is not venting at all or not enough. I have been told it may be the tank pressure sensor and the vapor canister or a evap solenoid. Can someone please steer me in the right direction!!! Check engine light is not on and I have had it hooked to a computer and send no codes. Please advise!! Much appreciated!
Old February 3rd, 2010 | 8:33 PM
game1939's Avatar
Default fuel oder
look under truck see wherether or not there is 2 lines coming from the gas tank to the spout where u put in the gas if there is 2 take the little one off and see if you can blow through it,may want to check holes where the hose was, if not that could well be a purge tank/soilned problem, a small vacumm leak in the evap system could cause odor but may not trigger a dtc. hope thisa helps
Chuck211
August 6th, 2013 12:09 PM
Dan Robertson
Sonic (Aveo)
April 16th, 2013 4:59 PM
M-21
April 15th, 2011 6:32 AM
tomkatb
March 28th, 2007 11:31 PM
