Fuel tank venting issue!!
Old Feb 2, 2010 | 11:53 PM
call0300's Avatar
Exclamation Fuel tank venting issue!!
I have a 2003 suburban 1500 5.3L and I am having a major gas odor coming from the truck after it has been runnging for at least 2 hours. When I remove the gas cap I get literally blown away and misted with gas. It seems like the tank is not venting at all or not enough. I have been told it may be the tank pressure sensor and the vapor canister or a evap solenoid. Can someone please steer me in the right direction!!! Check engine light is not on and I have had it hooked to a computer and send no codes. Please advise!! Much appreciated!
Old Feb 3, 2010 | 7:33 PM
game1939's Avatar
Default fuel oder
look under truck see wherether or not there is 2 lines coming from the gas tank to the spout where u put in the gas if there is 2 take the little one off and see if you can blow through it,may want to check holes where the hose was, if not that could well be a purge tank/soilned problem, a small vacumm leak in the evap system could cause odor but may not trigger a dtc. hope thisa helps
Chuck211
Aug 6, 2013 11:09 AM
Dan Robertson
Sonic (Aveo)
Apr 16, 2013 3:59 PM
M-21
Apr 15, 2011 5:32 AM
tomkatb
Mar 28, 2007 10:31 PM
