Gen III 4.8 into 84 SWB Chevy-need fuel system help!
Old Jul 2, 2008 | 4:54 PM
ad53030's Avatar
Default Gen III 4.8 into 84 SWB Chevy-need fuel system help!
Swapping 03-up 4.8L into 84 Chevy SWB. Originally 250 Straight 6/3 spd manual, single gas tank. Trying to do swap as cheap as possible. 03 up 4.8L/4L60 trans-100% stock. Immediate issue is the fuel system. Can't afford a Rock Valley Fuel tank, adapting stock system to work with externally mounted electric fuel pump. Any input on which fuel pump would work? Looking at Summit's part# SUM-G3137. Any thoughts? Is there a cheaper OEM alternative? Looking to use this in conjunction with 99-up Vette fuel filter that will allow a single fuel line to engine and the filter to return excess fuel to tank (kit from Street & Performance - hotrodlane.cc). Big prob here is that the filter is $72 from Chevy dealer but I cannot find the fittings needed to adapt the fuel filter other than from S&P. They want $40 per fitting & I need 3! Anyone know where or how I can do this cheaper? From tank I will flare factory 3/8" line & use AN-6 tube nut/sleeves make alum hard line into pump - into fuel filter assembly - to engine. I was told the return line does not need to be hi-pressure line & I could even run a good rubber line for the return. Is this true? Thanks for all help!
jeffbco
Dec 20, 2010 9:57 AM
meego123
Dec 2, 2010 10:59 AM
ExcessiveEgo
Apr 16, 2010 1:30 PM
kaligiurg
Sep 10, 2009 7:22 AM
ad53030
Jul 2, 2008 4:54 PM
