Heat not working in 95 Chevy truck
Old Jan 7, 2015 | 5:00 PM
Kyle51697's Avatar
Default Heat not working in 95 Chevy truck
So I got a 6.5 turbo diesel and the heat isn't working well it works every once in a while but there's no pressure. I have to hit the dash for it to kick on but it doesn't work every time. When it turns on there's a cracking noise like there's somthing in there but even if there was just somthing blocking it would still work every time. What could it be?
Old Jan 8, 2015 | 11:23 AM
Does it blow cold air? If it does then your problem is probably the blend door actuator.
Old Jan 8, 2015 | 8:49 PM
Kyle51697's Avatar
No it doesn't blow cold air
Old Jan 9, 2015 | 11:09 AM
If none of the vents blow any air then your problem could be the blower motor, the blower motor resister or the switch.
Old Jan 9, 2015 | 6:34 PM
Kyle51697's Avatar
Could you give me an idea of where those are located
Old Jan 10, 2015 | 11:12 AM
This
will help.
srussellnorton
Camaro
Mar 23, 2010 6:36 PM
fordsho90
Dec 12, 2008 11:25 AM
1981camaroz28
Oct 28, 2007 6:45 PM
tumark
Apr 15, 2007 12:58 PM
