heated seats problem
Old Dec 5, 2008 | 7:35 PM
supercharged SS's Avatar
Default heated seats problem
My 2004 Monte Carlo ss has heated seats and the driver side wont heat up properly it works and the passenger side works fine what the hell is the problem? Help me
Old Dec 5, 2008 | 11:26 PM
jkgray80's Avatar
Default RE: heated seats problem
[hr]
Heated Seat Inoperative (Monte Carlo) [/align]
[ol]Start the engine.
Operate the heated seat switch in the LOW and HIGH positions. [/ol]
Does the heated seat operate in low and high modes?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step3
Do the LOW and HIGH switch indicators operate properly?
Go to Step6
Go to Step4
Important:The body control module (BCM) is programed to supply voltage to the heated seat switch only while the engine is running.
[ol]Disconnect the heated seat switch connector.
Connect a test lamp from the ignition voltage supply circuit terminal in the harness connector to a ground. [/ol]
Does the test lamp illuminate?
Go to Step5
Go to Step17
Connect the test lamp from the ignition voltage supply circuit terminal to the ground circuit terminal in the heated seat switch harness connector.
Go to Step22
Go to Step18
[ol]Using a test lamp backprobe the seat heater element supply circuit terminal in the heated seat relay connector.
Operate the heated seat switch in the HIGH position. [/ol]
Go to Step12
Go to Step7
[ol]Disconnect the heated seat relay.
Connect a test lamp from the heated seat switch signal circuit terminal in the harness connector to ground.
Operate the heated seat switch in the HIGH and LOW positions. [/ol]
Does the test lamp illuminate in the HIGH and LOW switch positions?
Go tostep 8
Go to Step15
[ol]Turn OFF the ignition.
Connect a test lamp from the battery positive voltage supply circuit terminal in the heated seat relay harness connector to ground. [/ol]
Go to Step9
Go to Step19
Connect a test lamp from the battery positive voltage supply circuit terminal to the ground circuit terminal in the heated seat relay harness connector.
Go to Step10
Go to Step20
10
Test the resistance from the heated seat thermistor signal circuit terminal to the ground circuit terminal in the heated seat relay harness connector.
Is the resistance within the specified values?
7K-11KΩ
Go to Step11
Go to Step14
11
[ol]Measure the resistance through the heated seat switch from the heated seat switch signal circuit terminal to the heated seat switch high/low signal circuit terminal in the heated seat relay harness connector.
Is the resistance at or near the specified values?
[align=left]
HIGH 310Ω[/align][align=left]
LOW 200Ω[/align]
Go to Step27
Go to Step16
12
Disconnect the seat cushion heater element 4-way connector.
Test the resistance through the seat cushion heater element. [/ol]
0.5-2Ω
Go to Step13
Go to Step25
13
[ol]Disconnect the seat back heater element 2-way connector.
Test the resistance through the seat back heater element. [/ol]
0.5-2Ω
Go to Step21
Go to Step26
14
[ol]Disconnect the seat cushion heater element 4-way connector.
Test the heated seat thermistor signal and ground circuits in the seat harness for the following conditions: [align=left]
Open or high resistance[/align][align=left]
Short to ground[/align][align=left]
Short to battery positive voltage[/align][/ol]
Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step31
Go to Step24
15
Test the heated seat switch signal circuit for an open or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step31
Go to Step22
16
Test the high/low switch signal circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step31
Go to Step22
17
Test the ignition voltage supply circuit to the heated seat switch for an open or short to ground. Refer to Circuit Testingand Wiring Repairs in Wiring Systems.
Go to Step31
Go to Step29
18
Repair the open or high resistance in heated seat switch ground circuit. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
Go to Step31
19
Repair the open or short to ground in the battery positive voltage supply circuit to the heated seat relay. Refer to Wiring Repairsin Wiring Systems.
Go to Step31
20
Repair the open or high resistance in the seat heater control module ground circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step31
21
Repair the open or short to ground in the heater element supply or ground circuits in the seat harness. Refer to Wiring Repairsin Wiring Systems.
Go to Step31
22
Inspect for poor connections at the heated seat switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step31
Go to Step23
23
Replace the heated seat switch. Refer to Front Seat Heater Switch Replacement.
Go to Step31
24
Inspect for poor connections at the seat cushion heater element. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step31
Go to Step25
25
[ol]Replace the seat cushion heater element. Refer to Front Seat Heater Element Replacement.
Operate the Heated Seat System. [/ol]
Does the system operate normally?
Go to Step31
Go to Step13
26
Replace the seat back heater element. Refer to Front Seat Heater Element Replacement.
Go to Step31
27
Inspect for poor connections at the heated seat relay. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step31
Go to Step28
28
Replace the heated seat relay. Refer to Relay Replacement in Wiring Systems.
Go to Step31
29
Inspect for poor connections at the body control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step31
Go to Step30
30
Replace the BCM. Refer to Body Control Module Replacement and Body Control Module (BCM) Programming/RPO Configuration in Body Control System.
Go to Step31
31
Operate the system in order to verify the repair.
Did you correct the condition?[/align]
rsalas233
Mar 23, 2015 4:08 PM
Tim Opiekun
Feb 26, 2013 11:08 PM
jesien24
Oct 28, 2012 5:55 PM
gromelc
Nov 9, 2008 10:48 AM
digdug
Oct 5, 2006 12:52 AM
