help with 83 truck
Old Apr 28, 2012 | 9:31 AM
lonewolf1226's Avatar
Default help with 83 truck
Hi, my name is nate and i have an 83 chevy c10 that i cant get the tail lights to work on. my brake lights work unless i turn my head lights on then nothing works in the back and my turn signals and reverse lights dont work period. ive tried a new light switch to no avail. any advice would be greatly appreciated
Old Apr 28, 2012 | 10:48 AM
Attack it from the rear. Check the sockets at the taillights. make sure they are clean and are making good contact to the bulbs. Also make sure there is a good ground connection.
Old Apr 28, 2012 | 6:49 PM
Default help
that is one of the first things i checked after my earlier post. its a power issue it seems but i'm still clueless on how to resolve it. if i run a jumper wire from battery hot to the splice in the lights i can get them to come on so i checked continuity on my wires and they have continuity all the way to the connection box up front. im at a loss
Old Apr 29, 2012 | 12:01 AM
Go all the way to the switch. If you say you have continuity to the connection box then you have go to the switch and make sure power is coming out of the switch.
Old Apr 29, 2012 | 6:50 AM
Default confused
replaced switched with new one. could it be signal switch? light switch is new and hi/low switch works fine. no reverse light or blinkers or tail lights. brake lights work if lights are off but stop working once lights are on
Old May 1, 2012 | 11:50 AM
Default still need help
have replaced all rear wireing to no avail
Old May 2, 2012 | 7:49 PM
Scooch's Avatar
Site Ambassador
that sucks man. gonna move your thread to the tech section, hopefully you will get a little more help over there. and, Welcome to the forums... hope you get your issue worked out.
Old May 2, 2012 | 11:18 PM
Double the wiring at the switch. Something has to be wrong. You said if you run a wire from battery to lights they work. You might have to run new wires from switch to rear lights and bypass the problem.
Old May 3, 2012 | 9:30 AM
Ok. Ill' look into that. Thanks
dragonmaster
Sep 29, 2009 2:30 PM
chevy for a penney
Nov 19, 2008 1:36 PM
m0n0x!de
May 14, 2008 1:46 PM
chevyman1978
May 1, 2008 6:41 AM
