Monte Carlo won't Park!
Old Apr 29, 2012 | 12:41 AM
Chevychick18's Avatar
New User
Awaiting E-mail Confirmation
Default Monte Carlo won't Park!
My 2005 monte Carlo wont shift into Park... Just happened the other day out of no where... Does anyone know what could be wrong with it? Please help
Thanks
Old Apr 29, 2012 | 10:52 AM
cleveland63b's Avatar
does the shifter move all the way but the trans isnt shifting? or is your selector off too?
Old Apr 29, 2012 | 12:54 PM
2 things, the linkage may have come out of adjustment or there is a mechanical problem with the transmission. Get under the car and check where the linkage connects to the shifter arm going into the transmission. They use a lot of plastic tabs now and have been having problems with them breaking.
Old May 1, 2012 | 2:43 PM
RacerX's Avatar
05 Monte Carlo is a front wheel drive car, basically a 2 door Impala. The shift linkage is in the engine area in the area directly below the wiper motor or master cylinder.
Old May 3, 2012 | 9:15 PM
New User
It goes in every other gear, but the shifter will not go into park. My friend adjusted some kind of black line under the hood, and was able to get the shifter into park, but then they key would not come out of the ignition, and some of the other gears would not work. He said he thinks its something wrong in the shifter or the area around the shifter? But he's not sure exactly what?
Old May 3, 2012 | 9:31 PM
He threw the cable out of adjustment. That's why the other gears stopped working. You might be able to get it to the correct point to get everything to work. Since it quit working on its own, there is probably a problem with the cable or the transmission.
jetplanejay
Aug 30, 2023 2:43 AM
samuelkowal906
Aug 25, 2009 10:12 PM
Fritz823
Aug 12, 2009 3:43 PM
CanadianMonte
Mar 5, 2009 4:01 PM
