help me~
Old Jul 24, 2008 | 8:10 PM
papermill125's Avatar
Default help me~
hey guys 97 s-10, very hard to start give up at times, bought it for 150. sometimes i can get it running and after doing the fuel filter, plugs wires, and one coil. when it starts it will run decent, i drove it and it is smooth, starting it seems to be harder when its warm out side but once it has been running i can shut it down and start it again. if i give it more then 1/2 throttle it doesnt do so hot but still climbs rpms, no codes stored or pending. any other thoughts?
Old Jul 25, 2008 | 6:53 AM
Flying Low's Avatar
Ride of the Month
May 2008
From: Millbrook,Alabama...Slap dab in the middle of God's country
Default RE: help me~
Hey papermill125,welcome to the forum.
Have you looked for vacuum leaks. Also have your fuel pressure checked with a gage, these engines seem to have a problem there.
Old Jul 25, 2008 | 1:01 PM
is there a common problem for the low fuel pressure? regualtor or anything? bad pump ground? bad pump?or is it a number of things?
Old Jul 25, 2008 | 10:06 PM
old dog's Avatar
hey greeting's papermill 125 just for drill how many mile's ? and have you checked the compression ?
Old Jul 25, 2008 | 10:14 PM
Flying Low's Avatar
Ride of the Month
May 2008
Weak pumps and clogged pick-ups are not uncommon in trucks with that much experience.
David
Old Jul 26, 2008 | 12:14 AM
hey guys the truck has 159k on her. shes broke in a lil. i havent tried compression ( i dont have that sort of tools i worked mainly suspension when i was a mechanic) and no money at the moment to get them ( just had a baby boy) but i did buy a fuel ppressure reg but the torx is rounded holding the regulator on... its a biznitch to get to. any ideas how to get it out? how would i go about testing for a weak pump? just the fuel pressure gauge?
Old Jul 30, 2008 | 10:32 PM
Old Aug 1, 2008 | 6:24 PM
jkgray80's Avatar
4 cyl ,right? Remove fuel rail & get it on a table. Those bolts GM used on the regulator seem to be a little 'soft'. Also, if 4 cyl, it seems the head bolts stretch quite easily if a tad of coolant gets in cylinder(s). Check compression.
Old Aug 1, 2008 | 6:28 PM
jkgray80's Avatar
Check for weak pump by pushingpurge/sample button with engine running, pressure should not change. Fuel pressure should be around 50 psi w/engine running.
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
