horse power question
Old Jan 6, 2010 | 6:42 AM
demonseed304's Avatar
Question horse power question
i have a 93 GMC K1500 With a 350 tha was rated at 210 hp. I wanted to get aroud above 220hp. i swaped out the 2bbl tbi manifold for a 4bbl intake. i put a 600cfm edelbrock carb on top. and switched out the stock exhaust manifold for hedders. i am running from the hedders 3 in pipes back to hte muffler. how much hp will i get out of it. (the tbi unit was shot) thats why the modifications were made.
Old Jan 6, 2010 | 2:58 PM
nauticstar87's Avatar
the only thing that will truly tell is a dyno run. And 210hp is off the flywheel not the rear tires. On my 89 350, at rebuild, I put a mild cam, edelbrock heads and intake, bored .60 over, I had just under 300hp at the wheels.
Old Jan 10, 2010 | 5:33 AM
that was the factory hp rating i am not sure if it is at the weels or at the flyweel
Old Jan 10, 2010 | 5:49 AM
mudmaniac's Avatar
Ride of the Month
May 2009
That would have been at the flywheel. I would dare say that with the changes you made, you should have easily gained the 10 hp you were looking for.
Old Jan 10, 2010 | 8:53 AM
maxxman04's Avatar
by taking off the tbi unit, hp was lost. tbi is not the most efficient induction system, but does yield a slight better result than carb. although, you may have broke even, maybe even gained the 10 extra you were after. from the point you're at now, i would go with a slightly larger carb, 650 at least, then turn to ignition. get some QUALITY
Old Jan 10, 2010 | 11:14 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I agree about the carb, I think the stock units are rated at about 570 cfm, so a 650 would allow better flow. A cam will help alot but the stock heads while being very efficient and develop good torque, do have a very limited flow.
Old Jan 10, 2010 | 6:03 PM
maxxman04's Avatar
agreed. the heads play a huge role in it. depends on where he wants to go with motor, budget.
HNeto
Camaro
Jul 14, 2009 4:59 PM
petrou
Apr 3, 2008 7:36 PM
kfc6936
Nov 16, 2007 9:51 AM
y13supio
May 28, 2006 5:38 PM
