how much vacuum?
Old Feb 19, 2010 | 12:14 AM
maxxman04's Avatar
Default how much vacuum?
98 350 vortec, at idle pulls just under 12, just over 18 at higher rpms. what is normal specs for vacuum?
Old Feb 20, 2010 | 1:37 PM
therewolf's Avatar
The actual spec isn't as important as the uniformity. Does the needle flutter at idle or under load or hard acceleration? A steady, set uniform needle movement at different driving conditions is much more important than the set spec.
Not that it's bad to keep your reading values in mind. Hopefully somebody else can provide you with an actual number.
robertjhaley
Oct 15, 2014 8:18 PM
BrandanDeMamp
Apr 8, 2014 7:22 PM
BISCAYNE
Jul 3, 2006 7:54 PM
BISCAYNE
Jun 6, 2006 2:58 AM
