ineed help ! P0455
Old Mar 31, 2015 | 2:00 AM
myn2015's Avatar
Default ineed help ! P0455
Helo there every body !
i have a Chevy trailblazer 2006 LT, my problem is the check engine caused by P0455 , gas cap not tight triggers check engine ! IF any one has successfully repaired the issue , please show the way ,, Thank you all ,, thanks also to the administrators,,,hope to hear great tips soon ,, take care
Old Mar 31, 2015 | 3:47 AM
myn2015's Avatar
uppppp
Old Mar 31, 2015 | 7:48 AM
the evap system must seal itself to perform leak check diagnosis. if the evap vent solenoid does not close, a large leak dtc will set. check for power to the evap vent solenoid. it should have power with the key on. provide a grd for the vent solenoid. it should click when it opens and closes. if it doesn't, the solenoid is bad.
Old Apr 1, 2015 | 12:27 AM
myn2015's Avatar
Thanx a milliom tech 2! this is very helpful hint ,,, any one else owns a trailblazer 2006 had this problem gas cap not tight P0455 which triggers check engine and has successfully repaired the issue , it seems like this issue is common with this model... loots of cheers again to all of you
Old Apr 5, 2015 | 9:10 PM
myn2015's Avatar
Upppppppppp
Thanx
Old Apr 9, 2015 | 1:03 PM
myn2015's Avatar
Upppppp ,,, please help
hfdff
Mar 17, 2016 10:03 AM
Ecssound
Jan 23, 2012 5:19 PM
EddieClassic07
Dec 11, 2011 1:53 PM
XiBowhunter
Mar 22, 2010 12:29 PM
iss
Sep 2, 2009 9:48 PM
