knocking noise coming from inside passenger front floor board area when heat is on??
Old Nov 23, 2020 | 12:14 PM
MountainTodd's Avatar
Default knocking noise coming from inside passenger front floor board area when heat is on??
I have a 2000 Silverado 1500, ext cab., 4x4, auto., with 230k on it.
There is a strange knocking or tapping noise coming from the inside, front floor board passenger area (below the dash) when the heat is on, does anyone know what this is? The noise isn't constant, it comes and goes. My heat doesn't really work all that great either.
Thanks for all your time and help! .
Old Nov 23, 2020 | 2:35 PM
probably air diverter doors.
Old Nov 24, 2020 | 7:42 AM
Thanks! Do you know how to fix it? Are they easy to get too? Thanks again!
Old Nov 24, 2020 | 2:10 PM
Remove kick panels on passengers side and hunt down the actuators: one for temperature , and two for changing vent locations. They can be tricky to get to. Then just play with the controls and observe what happens.
Old Nov 24, 2020 | 6:26 PM
PNW NBS Z71's Avatar
You can remove the glove compartment and get a better look and use a mechanic's stethoscope to help pin point the noise source.
haznavy
Feb 1, 2019 3:23 AM
sudo
Apr 8, 2017 8:15 AM
tbohling
Colorado
Jun 22, 2011 7:56 PM
jheinen54
Nov 17, 2005 2:18 PM
