liftgate actuator replaced but still not working
Old Jul 31, 2015 | 11:13 AM
ernie888999's Avatar
Default liftgate actuator replaced but still not working
2009 suburban 1500 LT 4wd 5.3L
The liftgate and rear window stopped working. when you press the switch in the handle, you hear faint clicking sounds, the door remians locked. On the rear window, theres no action at all when you press the switch/.
I just replaced the actuator for the cargo door, same status. the harness has 11.75 volts on the digital meter. only 3 bolts are involved in putting the new part.
what else is there to check? Could I have a bad , new actuator? please advise where to check further.
thanks.
Old Jul 31, 2015 | 11:44 AM
i am referring to the rear window that is on the liftgate, not side doors.
Old Jul 31, 2015 | 11:58 AM
is there a module controller that i should check?
Old Jul 31, 2015 | 12:08 PM
how about cheking the switch that is on the handle? ill try removing it and check.
Old Jul 31, 2015 | 3:12 PM
the female harness of the actuator has 4 pins. which ones are the positive and the neg ative?
i want to test if the actuators would work when connected directly to the battery. if they work, then it has to be an electrica; problem aor switch.
can anyone help me identify where to connect the positive and negative terminals from the battery? i dont want to fry the module.
Old Jul 31, 2015 | 3:22 PM
one thing i noticed is that the light bulb of the license plate turns on whenever i hit the actuator switch located on the handle.
Old Jul 31, 2015 | 3:38 PM
127 views(ers) but not one reply.
rolfcar
Mar 29, 2017 4:31 PM
Bjj1805
Jul 24, 2015 1:54 AM
The_Stees
Mar 5, 2013 8:20 AM
endisnear
Sep 9, 2011 6:52 PM
cobalt89
Aug 30, 2009 2:38 PM
