low beam issue
Old Jun 6, 2020 | 9:07 AM
Terry Knuuttunen's Avatar
Default low beam issue
I have a 2012 Silverado, and the drivers side low beam doesn't work. I bought a package of 2 bulbs, installed both, and still neither work. I tested the bulbs (and the original one) and they all work fine.
I swapped out the fuse with the passenger side light, still doesn't work. I swapped out the relay, still doesn't work.
I put a meter on the light bulb socket, and when I turn the lights on I get 12vdc, but when I put the light bulb in, it doesn't work. The ground connection is good. I'm at a loss........ any ideas?
Old Jun 6, 2020 | 1:19 PM
sounds like a bad connector...splice in a new connector or remove the connector and hard wire the light.
Old Jun 6, 2020 | 1:34 PM
kevinkpk's Avatar
You might try contact cleaner, even though you are reading voltage, bulb contact to socket might just need cleaned.
Old Jun 6, 2020 | 4:07 PM
Default Fixed....
well I rechecked the continuity again, and I didn't have a good ground. I don't know where the light bulb socket ground terminates so I just spliced another wire to the ground line and terminated that to the chassis and now it works😀
Old Jun 6, 2020 | 5:25 PM
kevinkpk's Avatar
Thanks for replying, helps with troubleshooting future issues, glad you have it fixed.
Tim0625
2007 - 2013 (GMT900)
Jul 1, 2019 8:26 PM
dave2555
Captiva
Dec 4, 2018 11:33 AM
martin18152
Oct 15, 2017 1:28 PM
Native27
Dec 14, 2015 5:54 PM
Gunnywaldo
Jun 8, 2011 2:25 PM
