need fast help! q-jet floods out accelerator pump.
Old Mar 10, 2013 | 6:25 PM
stanman's Avatar
Default need fast help! q-jet floods out accelerator pump.
Rebuilt the cab, slapped it on and it floods bad. need to get to work please help!!!
Old Mar 10, 2013 | 6:55 PM
kevinkpk's Avatar
Float is not correct. <period
Old Mar 10, 2013 | 7:05 PM
kevinkpk's Avatar
If the float dosen't have a hole in it, the needle valve shut shut off basically with the top of the carb float parrell with the top of the carb. You should also make sure the needle and seat does shutoff. Did you replace them?
Old Mar 10, 2013 | 7:47 PM
stanman's Avatar
yes i replaced the needle and the brass fitting and the seal on it. I adjusted the float slightly and it doesnt leak as bad but its still leaking. I got good power but it kinda runs like crap now.
also smokes and burns my eyes a little so its to rich?
Old Mar 10, 2013 | 9:33 PM
stanman's Avatar
issue fixed. needle wasnt seated properly
BuddhaShotMyCat
Apr 23, 2014 8:11 PM
jpbama
Jan 8, 2009 1:45 PM
ddover
May 28, 2008 1:56 PM
ddover
Mar 28, 2008 1:54 PM
