No starting
Old Feb 3, 2015 | 10:58 AM
badmystur's Avatar
Default No starting
hello all,,have a 91 s10 2.8 v6 5 speed, truck will not start with key there is no clicking sound ,turn the key dash lights come on like normal but nothing,,battery is fine,terminals cleaned,tried by passing the clutch safety switch temporarily,still nothing,checked for 12 volts at the starter and there is,, you can jump/bump start it runs like normal,everything works no problems what so ever,,just wont start with the key,,don't want to start replacing several things to try to find problem,,any ideas or info would be great,thank you
Old Feb 3, 2015 | 11:21 AM
Could be a bad key switch, relay, shorted wire or solenoid. Check them all with a meter.
Old Feb 20, 2015 | 6:24 AM
leemike's Avatar
I also suffered from the same issue with my old car.
I God I sold ..........
Old Feb 22, 2015 | 3:53 PM
Rednucleus's Avatar
Have someone hold key in start position and give the starter a good rap with a hammer. If it starts, time to replace the starter.
Old Feb 25, 2015 | 8:47 PM
holland9000's Avatar
In order to troubleshoot a no-start problem, you need to start at the beginning of the line, the battery, and work your way back. Some tests for a no-start problem are simple, others are a pain in the neck and a technical nightmare. Nonetheless, you need to figure out why the car won't start. If your key won't turn in the ignition, try these:
1. check fuses
2. battery corrosion
3. dead battery
4. Bad Igntion Switch
5. Bad Starter Connection
some basics. if still unlucky, may need to ask for professionals' help. thanks
quackpe
Jan 31, 2006 6:24 PM
billyjoe72
Oct 21, 2005 4:33 PM
aimin74
Oct 6, 2004 2:10 PM
