Non starting problem for 5.7 litre (350 ci)
Old Apr 2, 2020 | 1:44 AM
Rizzo's Avatar
Question Non starting problem for 5.7 litre (350 ci)
Hi
I've got a 1979 Cadillac Seville 5.7 litre (350) Oldsmobile motor.
It cut out recently. The Auto electrician said it needed a coil pack as there was no spark to the plugs.
It was turning over OK.
So I bought a new coil pack, fitted it and it still turns over but doesn't start.
What have I missed guys?
Thanks.
Rizzo
Old Apr 2, 2020 | 6:49 AM
Might need a distributor or at least the pickup inside the distributor.
Old Apr 2, 2020 | 8:16 AM
Irish_alley's Avatar
I'm here for the party
by time you replace the parts in the distributor it sometimes cost more than replacing the whole distributor off ebay. like chevy said you have the pick-up coil and the ICM also to replace. you can test the ICM at the parts store and the ignition coil can be tested at the parts store or at home. and as far as i know the pick-up coil cant be tested and you have to remove and dissemble the distributor to get to it
Old Apr 2, 2020 | 8:17 AM
Distributor diagram for testing and assembly/disassembly
Old Apr 2, 2020 | 9:33 AM
Distributor componets test
Old Apr 2, 2020 | 2:48 PM
Rizzo's Avatar
Thanks for the information old chevy.
Much appreciated
Old Apr 2, 2020 | 2:51 PM
Rizzo's Avatar
Thanks for the information Irish_ alley.
I thought about buying the whole distributor set up, but the supplier said it wouldn't suit the car.
I'd better go back to the internet shop.
Rizzo's Avatar
Brilliant! Thanks
Old Apr 2, 2020 | 2:52 PM
Rizzo's Avatar
Awesome! Thanks again.
WI Alex
Sep 3, 2018 3:38 PM
swis19
Oct 15, 2010 7:05 PM
french2
Jun 16, 2010 4:01 PM
wvanallen
Jan 16, 2008 9:42 AM
