oil pressure gauge
Old Jul 25, 2023 | 1:05 PM
sallen4921's Avatar
Default oil pressure gauge
Hey guys / gals.. new to the forum..
I have a 2012 Silverado W/T -- I would like to install an oil pressure gauge ( to replace the oil pressure "idiot light" )
Have any of you guys attempted this?
I thinking possibly an "adapter" that replaces the original oil pressure sending unit, or possibly an alternative location to access?
Any help / suggestions would be much appreciated!
Old Jul 25, 2023 | 4:03 PM
LarryE's Avatar
Put a "T" fitting of some sort where the oil switch is and have both.
Old Jul 26, 2023 | 10:39 AM
sallen4921's Avatar
Thanks for the suggestion LarryE -- I was kind of thinking something along those lines might be the only choice...
Old Aug 8, 2023 | 11:26 PM
2001 chevy silverado's Avatar
yes i like "T-fitting"
i once drilled a hole in a Jeep block to add a guage. it all worked fine while I had it; but the metal was thin where i put the hole despite being my only real choice of where to put it.
using a T would be better than drilling a hole wherever that may be
Old Aug 9, 2023 | 11:25 AM
sallen4921's Avatar
Thanks for the reply! After doing a bit more research, i found that a company called Glowshift makes a " oil filter adapter" that once installed, provides the ports for oil temp, pressure ( i think 4 ports total) I'm still researching..
Thomas Neels
May 23, 2024 7:54 PM
Neilrfox
Aug 15, 2017 11:39 PM
privatecarp
Nov 30, 2014 4:56 PM
privatecarp
Nov 22, 2014 1:22 PM
kwoods
Dec 10, 2008 11:04 PM
