Old gasket removal? suggestions welcome
Old Apr 15, 2012 | 8:47 PM
Peter M's Avatar
Default Old gasket removal? suggestions welcome
Any tips on removing the residue from an old gasket from a tight area?
Im replacing the seals and gasket in the oil cooling unit?(the housing that you screw your oil filter to) It is inset somewhat *see 1st pic.
Its like the inside of a jar lid.
To make matters worse I have limited access to it so scraping it of from the side isnt much of an option. *pic 2
Attached Thumbnails Old gasket removal? suggestions welcome-photo-1-.jpg   Old gasket removal? suggestions welcome-photo-3-.jpg
Old Apr 15, 2012 | 11:14 PM
John from Canada's Avatar
Soak a rag in some parts cleaner, stick it up in there, and tie a plastic bag around it to hold it in place. That should help loosen up some of the old material enough to scrape it off..
Old Apr 15, 2012 | 11:36 PM
There are gasket removers you can spray on there to soften them up for easy removal.
Old Apr 17, 2012 | 9:20 PM
unclebugga's Avatar
if you can i have used a scotch brite pad with some brake cleaner on it. also they make scruby type pads that are circular that can be put on a end of a drill if you can get the replacement pads and use them by hand that will do the trick i would use some brake cleaner with it
Old Apr 18, 2012 | 8:38 PM
cleveland63b's Avatar
fold some emery cloth over a screwdriver
Old Apr 18, 2012 | 8:49 PM
RacerX's Avatar
paint thinner in an aerosol can?
or a thin wire wheel on a drill tip?
08LTZafRET
Jan 29, 2013 12:48 PM
asfan42069
Mar 13, 2011 1:57 PM
gotstylez
Feb 23, 2010 2:02 AM
gulfcoastjoe
May 4, 2008 12:38 PM
