General TechGood at troubleshooting? Have a non-specific issue? Discuss general tech topics here. IF YOUR QUESTION IS SPECIFIC TO A CERTAIN MODEL, IT DOES NOT GO IN THIS SECTION.
2013 Chevy Cruze LT 1.4 L Turbo 233 on the odometer 76 on new engine swap has ran really rough since the swap got done I have checked everything from plug to plugs timing new timing chain everything and still cannot get it to run smooth it throws anywhere from four codes to 26 codes at a time cannot get it to run smoothly cleared codes by going down the road and it got full engine power back full Boost brand brand new for about 5 minutes and then started running really rough again tried clearing the codes again did not do anything any help would be very appreciated picture has the code that is throwing as of right now as I'm typing this
Check the throttle body and wiring harness common issues after swaps. Also, verify the ECM grounds and connections; poor grounding can cause multiple erratic codes. If the throttle body is clean and wiring checks out, scan for live data to pinpoint the issue could be a faulty sensor or ECM problem.
Spoiler
It sounds like your Cruze’s rough running could be linked to ignition coils or carbon buildup, both common issues on this model. Just like troubleshooting car performance step by step, players at https://casino-ellada.gr/1-euro-deposit/ start small and gradually build up, enjoying steady progress with minimal initial risk. Careful checks usually reveal the solution.
