problem with 93 chevy lumina......
Old Mar 10, 2011 | 9:39 PM
chevguy86's Avatar
Default problem with 93 chevy lumina......
the problem with my 93 lumina is that it will not start unless gas is pressed down. then when released dies right away... only probs before this was idle while coasting was low almost dieing any suggestions ?
Old Mar 10, 2011 | 9:42 PM
RacerX's Avatar
tps sensor is probably bad. or the idle speed control valve.
Old Mar 10, 2011 | 9:57 PM
chevguy86's Avatar
thanks for the reply i think im going to try and clean the idle air control valve and throttle body and see if that does it.
Old Mar 12, 2011 | 1:53 AM
chevguy86's Avatar
well im still not sure whats up with it tried cleaning but still no difference. it only starts when i push the gas and i noticed it smokes alittle and backfires from engine. also some smoke comes from engine any ideas what could be causing this ???
Old Mar 12, 2011 | 10:02 PM
RacerX's Avatar
get a paperclip and stick into the #1 and #2 slots on the computer interface by your right knee on the bottom of the IP. Count the flashes that come on the Instrument cluster from the engine symbol. It will flash 12 three times and then give you the stored engine codes. there are probably a couple of codes in there.
Old Mar 14, 2011 | 8:09 PM
chevguy86's Avatar
wow i think i found out what the problem was. it was just a simple throttle adjustment now its idling like it should and staying running.
Hector Aguilar
Dec 30, 2012 7:52 PM
trunks9_us
Dec 8, 2012 1:21 PM
bozsozsoltika
Mar 26, 2011 4:19 PM
SilentObserver64
Mar 1, 2011 5:35 PM
MagicElectric
Feb 27, 2007 3:42 PM
