Rebuilding sbc 350 for 4x4. Cam and piston suggestions
Old Sep 12, 2018 | 7:56 PM
fatcat92's Avatar
Default Rebuilding sbc 350 for 4x4. Cam and piston suggestions
Sffff
Old Sep 12, 2018 | 8:16 PM
geo1's Avatar
Great choice on cam,just remember,high rpm's cost money,to keep the engine durable,so if it's life is going to be normal,not 5k rpm,stock heads will be fine
Old Sep 12, 2018 | 8:29 PM
fatcat92's Avatar
Sffffgg
Old Sep 12, 2018 | 8:35 PM
geo1's Avatar
Yep, homework is always good,the problem on a build is ,where to stop?stock springs are fine for normal rpm use,same with a hei distributor, but,new ones, maybe?what's the milage on the heads
Old Sep 12, 2018 | 8:46 PM
fatcat92's Avatar
Yeahrr
Old Sep 12, 2018 | 8:52 PM
geo1's Avatar
I'm sure some offroading sites will prove valuable, imagine if money was no object?what would you wind up doing then?scary,lol
Old Sep 12, 2018 | 9:01 PM
fatcat92's Avatar
Sassasaas
Old Sep 13, 2018 | 3:31 AM
oilcanhenry's Avatar
Originally Posted by fatcat92
Probably end up doing wheelies down the freeway! Thanks for replying! Yes I'm looking around now and have gotten a better general idea of what I should be after. Trying to get as much low end power without increasing my compression ratio too much I suck up too much $$$ worth of gas as it is! If I have to run one grade up so be it but ideally would not like that!
Whatever cam you decide on I'd go with a Cloyes timing chain. They are built like a rock and worth every penney.
Old Sep 13, 2018 | 9:48 AM
therewolf's Avatar
To the man should you listen! Wise is he! Mmmmm.
OK all Yoda aside, I would go with a milder cam for a couple reasons. Gas mileage is one. Less tear on that new bottom end is another. one thing which many folks ignore about racing
parts is the shorter life span of racing engines, in general. When sponsors are replacing their engines after 2 or three weeks, what do they care?
Old Sep 13, 2018 | 8:17 PM
fatcat92's Avatar
Was looking at the lunati voodoo cranks, maybe that would be a better option?
