Rpm
Old Dec 17, 2009 | 5:30 PM
deadwood's Avatar
Question Rpm
here is my problem when i start up my chevy 1500 hd with a 6.0 the rpms read 6000 rpm and wont return back to the acutal reading of the rpm but if i shut the truck off and start it 5 or 6 times it slowly brings it down so i was wondering what the problem is thanks
Old Dec 18, 2009 | 12:41 PM
JCSkokos's Avatar
sounds like your tachometer might be stuck. it may need replacing
Old Dec 19, 2009 | 4:00 PM
deadwood's Avatar
Question rpm
my tac works fine ill be driving around and it would be acting normal and then all of a sudden it would read 6 thousand rpm then i will shut the truck off and start it back up and it will read 5 if i keep doing that it will keep dropping it 5 thousand rmps at a time until it reads normal operation i hope you understand what im tryin to say here it may sound confussing thanks
Old Dec 19, 2009 | 4:06 PM
nauticstar87's Avatar
Possibly a bad ground, or the stepper motor.
Old Dec 20, 2009 | 11:31 AM
JCSkokos's Avatar
the bad ground is entirely possible, a friend of mine had an old Buick that the tach and speedometer werent working. He replaced the motor mounts and both worked again.
Old Dec 28, 2009 | 6:02 PM
deadwood's Avatar
Default rpm
now get this when i went to drive it today i looked down and the speedo wasnt working and the tac was working but if i shut the truck off and start it 2 times and then drive it my speedo started to work again so my question is, is my cluster going bad or is there a sencer going bad or a bad ground somewhere thanks
porrsher
Oct 15, 2020 6:42 PM
95white lightning
May 18, 2007 12:55 PM
Z71chevyoffrd
Jan 25, 2007 8:24 PM
94burbin
Sep 24, 2006 12:10 PM
djdiplomat
Jul 3, 2006 10:42 PM
