Security warning light on???
Old Jul 30, 2006 | 7:21 PM
duggger's Avatar
Default Security warning light on???
I have a 2002 Trailblazer LS, and it won't start today. The "service engine soon" light is on and the "security" light is blinking when I try to start it. What do I have to do to start this car?
Doug
Old Jul 30, 2006 | 10:39 PM
LuangTom's Avatar
Default RE: Security warning light on???
Sounds like the PassLock system is needing a re-boot. Security-system light is blinking, then
turn the ignition-key to the ON position. Wait ten to twenty minutes until the lights stops its
blinking or goes off, then turn off the key and re-start car. This should reset the PassLock.
Old Jul 31, 2006 | 11:40 AM
duggger's Avatar
Thanks for the advice. I'll try it and let you know how it went.
Doug
Old Aug 4, 2006 | 3:16 PM
duggger's Avatar
Here's an update...I had the car towed to the dealer. They're looking up some security codes for it. They don't know what to do yet. I'll let you guys know what I learn.
Old Aug 14, 2007 | 10:03 PM
kolby's Avatar
What did you learn? I am having the same issue...
Old Nov 7, 2007 | 9:43 AM
jla74's Avatar
There are alot of people with this issue and there are never any responses from people letting us know if they were able to get it fixed or not. Some people have bypassed the passlock issue to get around their problems but what about GM fixing the problem.ANYONE??????????
Old Nov 8, 2007 | 8:00 PM
martinchevrolet's Avatar
Typically the passlock sensor has to be replaced. Its pretty common.
Old Nov 9, 2007 | 6:55 AM
jla74's Avatar
Martinchev.
Thanks for your post. Do you work at a dealership? Appears you are pretty confident in the cause. If so hang around others on the forum will really appreciate it.
Is it an expensive part to replace? It seems that if it was this common there would be a recall on the affected vehicles.
Old Nov 9, 2007 | 11:21 AM
jla74's Avatar
The passlock sensor is located inside the ignition switch. It is my understanding that this will need to be replaced as well as the tumbler assembly. Total cost to me the consumer..$444.83. This is supposed to be the updated version. I guess that means they know there is a problem.
Old Feb 5, 2008 | 10:54 AM
jla74's Avatar
Well just when you think everything is going well...BOOM it all starts again. It has only been three months and today I get the call from the Mrs. very unhappy and stuck in a parking lot with the same problem. The dealership just replace the ignition switch last Nov. and now the problem is starting again.
Donald Laird
Dec 17, 2012 2:45 PM
wileycoyote
Mar 28, 2011 5:27 PM
jffgin
Feb 2, 2008 6:45 PM
r970
Jun 3, 2007 8:16 AM
SJVENTURE
Dec 11, 2006 5:47 PM
