Service 4wd light code c0306 range actuator short to ground
Old Aug 24, 2020 | 11:42 AM
Matt Charboneau's Avatar
Default Service 4wd light code c0306 range actuator short to ground
I have a 2004 Silverado 5.3l and My service 4wd light Is on. The code I have is c0306 range actuator short to ground. My 4wd selector is lite up. If I try to put it in anything it will blink then go back to 2wd. Randomly it will work, like once a month maybe. How do I go about testing this? What could it be? The ground wires on the frame under drivers side door are completely clean and tight as for that’s the first thing i did. I looked at all the wires under the truck and everything looked fine. Any help would be appreciated. Thanks
Old Aug 24, 2020 | 12:44 PM
kevinkpk's Avatar
Might be a short in the servo itself. I don't know what they cost. If you have an ohmeter check the connector each side to ground, and across the servo.
trebreklaw
Jun 7, 2022 6:45 AM
fsxbob
12
Jul 21, 2021 10:44 PM
Gottwchr000
May 5, 2018 1:23 PM
04BLK8.1
Jan 4, 2016 9:59 PM
debra1
Aug 13, 2010 11:40 PM
