stuck in neutral?
Old Dec 14, 2013 | 10:10 AM
adaml1929's Avatar
Default stuck in neutral?
ok so I have an 05 Silverado half ton, non hd 4x4 with the 5.3 automatic. and lately we have been having some really cold weather down to zero and up to ten lol, on one day on my way home ( truck is warm already drove about 45 miles ) I am in 4wd drive on a snow covered road the truck stops moving, the engine is still running but no power to the ground, I push the button to go to 2wd and same thing no power to the ground. I though maybe the shifter cyloniod was possibly freezing and acting up but we are now into the mid to high 40's and still no power to the ground, I have no clue? oh and the tranny and transfer case both are good for oil. any advice on this would be greatly appreciated. thank
adam
Old Dec 14, 2013 | 12:08 PM
adaml1929's Avatar
oh and also there are no engine codes. thank you
adam
Old Dec 14, 2013 | 1:02 PM
does the t-case range switch have a neutral position. do you think the t-case is in neutral? if this the case the truck will roll even with the trans in the park position.
Old Dec 14, 2013 | 1:06 PM
adaml1929's Avatar
no there isn't a neutral spot on the switch, the truck also does not roll when in park. I am definitely confused? thank you
Old Dec 14, 2013 | 4:16 PM
ses light on? if yes post them here. Is the trans fluid brown an smelly? If yes, you could need a rebuild.
Old Dec 14, 2013 | 7:47 PM
adaml1929's Avatar
tranny fluid and transfer case fluid are both normal, no engine codes.
Old Nov 28, 2019 | 6:41 AM
JeffW183's Avatar
Broken driveshell in the trans
tlaura21
May 12, 2026 7:00 AM
mrpurplehawk
Jun 23, 2014 10:59 PM
BigblackHo3
Apr 5, 2013 8:54 AM
terokyle
Jul 25, 2010 12:44 AM
tweetzangl
Feb 21, 2010 9:26 PM
