Tranmission question
Old Sep 13, 2019 | 8:47 AM
Ethan Northrop's Avatar
Default Tranmission question
Hello guys,
I have a 2012 chevy Silverado. Single cab, 8ft box. It has the 5.3L with manual 4x4 on the floor. I got the transmission serviced at 43,000 miles and the shop said there was a substantial amount of metal that came out. From what I have been reading people are saying that's just because it was the first service, other people are saying that the transmission is eating itself? Opinions? \
Thanks, Ethan
Old Sep 13, 2019 | 9:32 PM
ask them to show you the "substantial amount of metal".
Old Sep 13, 2019 | 10:28 PM
yep. pics needed.
Old Sep 14, 2019 | 6:07 AM
oilcanhenry's Avatar
Originally Posted by Ethan Northrop
Hello guys,
Thanks, Ethan
What Tech2 and MMJ said.
Any new transmission, automatic or manual has to "break-in" so the first fluid change will have break-in metal as part of the flush. If its a NV-3500 it should have a magnet on the drain plug, or at least my Chevy 1998 K-1500 pickup does, but cant say about a 2012. I would highly recommend using a fully-synthetic,Syncromesh fluid on refill, not any kind of ATF fluid.I use Royal Purple Synchromesh fluid. Expensive, yes, but she shifts as smooth as silk.
Old Sep 18, 2019 | 10:28 AM
Ok I will call them and ask them what they put it. I'm Leaning more towards it just being the break in period. I don't know what they put in but should I add some additive next time or change the fluid again?
Old Sep 18, 2019 | 10:29 AM
They didn't take pictures, just wrote it on the receipt
Old Sep 18, 2019 | 10:30 AM
He called me and told me that because I told him I was taking it to NC the next day. She made it out and back this fine. 2700 miles. He just wrote it on the sheet. Could it just be break in period?
Old Sep 18, 2019 | 3:35 PM
kevinkpk's Avatar
Also need to know if it's steel, or brass, could be sync gear break in.
Old Sep 20, 2019 | 8:16 AM
Ok I should call them and ask them what it was then
Old Sep 20, 2019 | 8:44 AM
https://ricksfreeautorepairadvice.co...sion-magnetic/
if you are not having any trans problems and no dtc are settting….drive it. If it is showing problems...it needs a teardown. If it fails...its needs a teardown. Its the same boat regardless.
rollie88
Nov 21, 2015 12:54 PM
GeorgeSmith
Oct 10, 2013 6:13 PM
73Chevelle
Feb 1, 2010 12:29 AM
darkskye19
Apr 22, 2008 8:30 PM
RedneckBoy1861
Apr 30, 2006 11:54 PM
