Transmission Problems??
Old Aug 23, 2008 | 12:02 AM
Sturmvogel's Avatar
Default Transmission Problems??
Hello everyone,
I'm coming with the following OBDII Codes, and I was wondering if there is anything that I can do to further diagnose the issues myself?
p0742 Torque Converter Clutch Circuit Stuck On
p0757 Shift Sloenoid "B" Stuck On
Thanks in advance,
-Kirk "The non-mechanicaly inclined Venture owner
Old Aug 25, 2008 | 12:52 AM
Bizzy23's Avatar
Default RE: Transmission Problems??
You should check the wiring to them. just because the computer says there's a problem with them doesn't mean the component itself is bad. You should also make sure that everything else in the same circuit as those components is functioning properly.
-Bizzy
Coravir
Oct 26, 2019 3:28 PM
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
amos221
Mar 11, 2007 1:41 AM
