Transmission problems
Old Jan 25, 2014 | 5:18 PM
thad4411's Avatar
Default Transmission problems
On my Chevy,I noticed that the transmission wouldn't go into gear. Reverse or any gear would work.Went outside the next day when the weather was 13 degrees and the transmission would go into gear with no problem.The weather was 52 degrees 2 days later and it wouldn't move in any gear. The fluid has not been changed since i got the truck from the previous owner,but its very dark, and thin like water. Will changing the fluid and the filter fix the problem?
Old Jan 27, 2014 | 1:43 AM
SWHouston's Avatar
Yes, I'd change the Fluid, and, add a good Cleaner as well.
After it starts shifting at normal temps (I feel that it will) you'll need to change the Fluid again to remove the Cleaner. I think that will do it !
Follow the Cleaner Manufacturers directions to the letter !
Old Jan 30, 2014 | 10:50 AM
Richardx2's Avatar
ditto
Coravir
Oct 26, 2019 3:28 PM
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
amos221
Mar 11, 2007 1:41 AM
