Transmission or Transfer case vent spurting fluid ?
Old May 8, 2017 | 3:12 AM
Shep6654's Avatar
Default Transmission or Transfer case vent spurting fluid ?
2000 S10 ZR2 4.3 4x4 auto.
A vent tube connected to the transmission dip stick is spurting fluid. A neighbor said he thinks its to the transfer case. Anyway why is it venting fluid ? If itis the transfer case Is this something that I can fix or a serious problem ?
What parts will I need? & would there be anything ese that should be replaced while its apart? Transmission fluid is low and TC is overfilled.
Thank you
Old May 8, 2017 | 6:46 AM
kevinkpk's Avatar
Thank you
I think you solved the issue
Old May 8, 2017 | 7:51 AM
Before you do anything else, make sure both the transfer case and the transmission are filled to the proper level. Then see if it is still venting fluid.
