Transmission or Transfer case vent spurting fluid ?
2000 S10 ZR2 4.3 4x4 auto.
A vent tube connected to the transmission dip stick is spurting fluid. A neighbor said he thinks its to the transfer case. Anyway why is it venting fluid ? If itis the transfer case Is this something that I can fix or a serious problem ?
What parts will I need? & would there be anything ese that should be replaced while its apart? Transmission fluid is low and TC is overfilled.
Thank you
Thank you
Thank you
Thank you
