Truck has trouble starting in the morning
Old Jul 7, 2020 | 5:57 PM
Twaquan's Avatar
Default Truck has trouble starting in the morning
I have a 1999 Chevy 3/4 ton truck. Ive been having trouble starting it after letting it set overnight. It takes about 2-3 minutes before i get it to start, but then it starts fine all day long.
It's even more difficult to start on the morning after it rains. I have to crank it for about 5 minutes, then the engine backfires and then it fires right up.
Someone said it could be a timing chain, but it starts fine throughout the day. I only have trouble starting it after it sits overnight.
Old Jul 7, 2020 | 9:24 PM
Rednucleus's Avatar
Maybe a bad check valve so fuel needs more time to get back to motor after sitting. Next time it has not run for a while, try turning key on & off to let fuel pump run several times before trying to turn it over.
Old Jul 8, 2020 | 7:18 AM
You can add a check valve into the fuel line if you don't want to go through the bother of replacing the fuel pump.
kwikrider
Jan 16, 2020 11:38 PM
jvdh
Captiva
Feb 6, 2015 11:16 AM
inkdawg
Nov 16, 2014 9:07 AM
davemec
Aug 7, 2007 11:50 PM
abew330
11
Apr 15, 2007 1:41 AM
