tunning help
Old Sep 17, 2007 | 8:27 PM
milbags's Avatar
Default tunning help
well guys im kinda having some problems.. i have a 305 chevy truck 86.. i was having probkems with no power , so i thought to change the carb, so i bought a eldebrock 1403 carb and a performer intake .. the truck has power now but we seem to have a problem the truck runs off after you stop the truck. like you turn it off and she still runs for like 10 seconds and she idles at like 3000 rpm when at idle most of the time. also it seems everytime you punch the gas the truck dies right after that ....
what should the timing be at
and how do i fix this problem
Old Sep 17, 2007 | 9:59 PM
John86's Avatar
Default RE: tunning help
for the high idle u need to adjusted ur idle screw on the side of ur carb. the dieseling when the key is off sounds like maybe ur timing is off. i wanna says it's supposed to be around 6btdc but not a 100% on that.
Old Sep 18, 2007 | 6:25 AM
astroDZak's Avatar
I agree with John86 about the timing probably being your problem with the dieseling (run on).
Since you had to pull the distributor to change the intake have you put a timing light on it yet to see where its timed at now?
A lack of power until you have changed the carb out doesn't necessarily mean it was the carb in the first place. Having the distributor turned too far advanced would make the motor race and give you added power but would also shoot all milage to heck and create a run on "diesel" condition.
What I am wondering is how bad is your timing chain and has it possibly jumped a tooth? When you have the timing light on it does the mark jump all around? If so I would be changingthe timing setwhile its in the shop not out on the road broke down
ChevyNorway
Sep 14, 2013 6:05 AM
HIDEYOURWOMAN
Aug 29, 2013 7:46 AM
jharper
Dec 11, 2007 4:15 PM
star_diagnose
Oct 31, 2007 10:00 AM
wwotr
Mar 24, 2007 8:11 PM
