Notices
universal joint replacement
Old March 15th, 2011, 8:00 PM
wvlewis's Avatar
Default universal joint replacement
I have a 1994 chevy silverado 4x4. Need suggestions on how to replace the universal joints correctly. Any tips on what to do or not to do. Tools needed etc. Please be specific on removeal and replacement. Thanks for any advice. wvlewis
Old March 15th, 2011, 8:29 PM
Senior Site Administrator
nj85z28's Avatar
What I have done is use the ball joint press/ujoint press.
Remove the drive shaft straps and pull it out. I placed the yoke in a vise and sprayed wd40 all over the caps. I removed the c-clips and pressed the ujoint all the way to one side. Remove the cap and press it all the way the other way removing the other cap. Installation is pretty much opposite of removal, but be very careful with the needle bearings inside the caps.
jonamond
Silverado & Fullsize Pick-ups
April 3rd, 2015 4:59 PM
joshhighley
September 23rd, 2010 11:46 AM
kellyguinn
September 1st, 2008 1:40 PM
gmanmdg
August 18th, 2008 11:16 AM
nativebroncofan
February 13th, 2007 3:24 PM
Quick Reply: universal joint replacement
