vaccum advance
Old May 13, 2019 | 10:40 PM
Mike Stansbury's Avatar
Default vaccum advance
when its hooked up to full manifold vaccum my idle goes way up and comes down very slow
Old May 14, 2019 | 12:31 AM
oilcanhenry's Avatar
Need more input here. What year, make model and engine do you have? How many miles on the odo?
Old May 14, 2019 | 8:30 AM
A 1980 Malibu 350 about 200. Miles on motor
Old May 14, 2019 | 9:40 AM
Irish_alley's Avatar
I'm here for the party
whats your timing set at without it hooked up?
Old May 14, 2019 | 11:02 AM
About 12 advanced
Old May 14, 2019 | 4:06 PM
kevinkpk's Avatar
First, I'd set the timing back to 8, is it hard to start?
Old May 14, 2019 | 4:22 PM
No starts up right away,but with my cam I need more timing.
Old May 14, 2019 | 4:33 PM
When I run the car with the advance not hooked up it's fine,throttles nice and it comes right back to idle
Old May 14, 2019 | 8:06 PM
Does the vacuum line run directly from the carburetor to the vacuum advance unit? Back in the 1970's and for some of the 1980's, the vacuum line would be connected to
a small device that would slow down the drop and rise in vacuum, and was an early smog control device, that is why I ask this question.
Old May 14, 2019 | 9:10 PM
kevinkpk's Avatar
The cam is not standard, or is built to this engine? At what idle rpm do you have X vacuum? What is the vacuum at say 700 rpm? As oilcan has pointed out, yes the older cars (I have a 70 delta 455 with remninants of smog control) that had a tps that also controlled vacuum advance. This was a small ported attachment. My suggestion is for vacuum advance to set the timing without vacuum, and use a vacuum port from the intake manifold, not from carb, shew, long winded.
