vavle train noisey
Old Aug 23, 2009 | 9:04 PM
blakesduc's Avatar
Default vavle train noisey
question on a small block chevy lets say a 350 with stock roller lifters and valvetrain how much oil should come out of the rocker arms
at idle.
Old Aug 23, 2009 | 9:09 PM
blakesduc's Avatar
I have a noise from both sides of engine with about 60 psi oil pressure nise is there hot or cold I remove the right valve cover and some rockers were shotting oil out 5 inches or so while others were very low rockers have no free play and noise seems to be quieter with the rpm raised . engine had set for a good while I have ran a quick flush threw it and changed the oil 4 times but noise hs not changed.
Old Aug 24, 2009 | 11:40 AM
therewolf's Avatar
It's natural for a properly adjusted valve train to "slap" a little.
If you get it too "quiet", you're enabling the combustion fire to escape from the combustion chamber a little each pass, which will quickly scorch your valves.
Most motor pool workers will advise you to leave the rockers just a hair loose.
Old Aug 25, 2009 | 9:26 PM
blakesduc's Avatar
this engine has none adjustable valves has bottom out type studs and shots oil at least 7 inches out of rockers at idle
richolsen
Mar 14, 2010 6:56 AM
mygreenihc
Apr 28, 2009 10:11 PM
dalehughes
Jan 2, 2009 12:45 PM
hawkeye1734
Mar 11, 2008 6:11 PM
brims
Dec 8, 2006 2:28 PM
