Water Pump Question...
Old Jan 11, 2009 | 6:49 PM
dcoperator's Avatar
Default Water Pump Question...
I have a 94 Olds w/3.1 with a circulation problem. Engine will get to 200 degrees but heat in cabin is not great unless you increase rpms. Replaced thermostat today but not satisfied with heat. Could a water pump be bad without leaking?
Old Jan 11, 2009 | 7:23 PM
MDTAHOE's Avatar
Professional Mechanic
Default RE: Water Pump Question...
Your problem is not with the water pump. If the pump was bad it would overheat.You have a blockage in the system, most likely in the heater core. Remove the 2 heater hoses from the engine then pour a small bottle of peroxide in and let it soak for about 1 hour. Then take the garden hose and squirt through the core. Reassemble run the car till the air pocket burps ( when cooling fan cycles your good) and see what happens.
Fightn17
10
Apr 8, 2010 12:45 PM
slt
Sep 17, 2007 9:28 PM
67copo
Dec 11, 2006 2:36 AM
slt
Jun 16, 2006 8:51 PM
